Ana içeriğe geç
Curtis International tarafından RCA adı altında üretilen, RT2806 model numarasına sahip 28 inç LED TV için onarım bilgileri.
TV won't turn on
Resim
Resim
So my model number is actually rled4627a
And it won't turn on upon plugging it in after waiting some time ill get the red light that there's power
When I try to turn it on I get the green light then immediate power down. No red light unless I unplug and wait 10 mins
Now before it just wouldn't turn on for the past 4 months or so upon start up it would turn of and on about 4-5 times before powering up.
I've removed the back panel to check the power supply im equipped with a multi meter but totally lost wonder how to check the capicotors and maybe sodder a new on in any help would be great repair shop wants 90 dollars for diagnostic a new tv at Walmart is like 260 anyway
Resim
Resim
Resim
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I would start measuring components on the power supply board (yellow). It might just be the angle from which you took the photo but I would start with diode (D15), an the bigger 330uF 25V capacitor above L2 which appears to be bulging slightly. As it is not fully bulged yet, it may cause your intermittent workings of your TV.
Should everything work as it should, I would measure if you get a stable 24V on the connector above CF1.
If the tv works intermittently, it is often harder to diagnose than a completely dead device.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
archie-comics sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 335
