Ana içeriğe geç
Xbox One oyun kolu, 2016 yılında Xbox One S'in piyasaya sürülmesiyle tanıtılmış olup Windows 10/11 için Bluetooth desteği eklemiştir. Bu oyun kolu, Model 1537/1697 oyun kollarında bulunan birçok tasarım kusurunu düzeltir ve çok daha güvenilirdir. Bu oyun kolu, geliştirilmiş Model 1914 oyun kolu ile değiştirilmiştir.
Controller doesn't want to work via USB connection
Hello! I’m using my Xbox controller plugged in via USB cable without batteries. Yesterday, it just simply stopped working. It seemed like a driver issue at first, the controller buzzed when plugged into USB port, but was not connected. It also takes power from the USB port and when I’m pressing the middle button it connects via Bluetooth normally. tried reinstalling the drivers, testing 2 other cables and plugging the controller into my laptop. So It doesn’t work with any of my cables or my PC or laptop, it does take the power from the USB but doesn’t connect via USB.
Any ideas on how Can I fix it? I know I technically can use the cable as batteries and connect my controller via Bluetooth, but due to various medical devices I use I would prefer to avoid it.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum:
I have this same problem as well, have you found a solution?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Stupid question but have you tried plugging the cable into different USB ports? USB ports can partially die and switch to only giving USB power.
Bu yanıt yardımcı oldu mu?
Puan 0
5 Yorum:
Yes. 3.0 USB ports, 2.0 USB ports, different cables, different PC's. It simply doesn't detect it as a device. The controller gives one buzz and it is supplied in terms of energy, but it doesn't want to connect. via the cable.
tarafından
@themiziko OK, pretty sure your controller stopped sending any USB data.
RIP your controller 2021-2021
tarafından
Even if it is taking the power? Can't it be something with the motherboard? or one of the 5 connectors in the USB port? it kind of doesn't make sense to me that all of a sudden it just .. died? it didn't even fall or anything
tarafından
@themiziko Sounds like either a damaged port or a damaged controller. Have you made sure there aren't any missing or bent pins in the port?
tarafından
@spudpiggy Yes indeed! the pins look perfectly, all of them are connected, and the cable sits firm in the controller and doesn't move in any direction so it's not loose. I guess it's time to buy a new one :) but I was just surprised that I took such good care of it, it never fell or was damaged, and it just died. but I guess it's my luck :)
tarafından
Yorum Ekle
blue controller xbox not play good fine usb
Puan 0
Yorum Ekle
Yanıtını ekle
Divine Kataroshie sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 65
Her zaman: 4,409
