Ana içeriğe geç
İnce, hafif ve şık Swift 3, hareket halindeyken çalışmak için ideal bir dizüstü bilgisayardır. En yeni NVIDIA® GPU, Intel® CPU ve uzun pil kullanım süresi, iki farklı ekran seçeneğiyle sunulur: 13,5 inç 3:2 oranlı 2256x1504 IPS VertiView Ekranlı zarif gümüş kasa veya 14 inç 16:9 FHD IPS ekranın canlı renkleri.
My laptop won't charge
Hey, so my laptop has stopped charging after 3 years. I tried a different power cable but that's all. The problem could be anywhere form the power pack down. I've never had any issues like this before so I have no idea what it could be. Should I try to fix it myself?
Don't really want to spend 200 euro to repair something that cost me 800
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
2 Yorum:
At least try to open it up and see if you find anything obvious (burnt components, water damage, etc...) Maybe post some photos of the motherboard...
tarafından
Hi,
What is the model number of the laptop?
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Check the AC adapter brick and verify that any removable cords are fully inserted. Make sure the battery is properly seated in its compartment, and that there is nothing wrong with either the battery or laptop contact points.
There are also some basic troubleshooting steps you can follow.
Otherwise remove the battery completely from the laptop and try running the laptop using the AC adapter. If you can use the computer for a couple of hours without problems, the adapter is obviously okay. Clean the battery contacts. Replace the battery and try charging it again.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Check the connector and the jack.
If the pins are no longer sticking out enough to “grip” when inserted - (maybe) all you need to do is bend them a bit so they provide the holding power they used to - when everything was new.
Puan 0
Yorum Ekle
It's probably the charger l bought a charger off ebay for my laptop and I thought the laptop was broke but it wasnt broke something was wrong with my charger.
Puan 0
Yorum Ekle
Yanıtını ekle
danielforbes1 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 6,220
