Ana içeriğe geç
The Acer B326HUL is a 32-inch (81.3-cm) display monitor with a resolution of 2560 by 1440 pixels.
3 Soru Tümünü görüntüle
LCD AOC monitor WJI780PI fault
Hello,
Sorry I chose any device above as I could not find AOC. LcD monitor WJI780PI. Power rating 100-240v-60/50hz 1.2 . It is connected to a DVR4-4580v. There was a power outage which lasted for several hours. When the electricity came on all devices came back on apart from monitor. I swapped the power cable with another and when switched on the monitor power light lights up for a few seconds and then disappears. Is there a way to fix this?
The DVR works fine, but I need a monitor. I am worried if I am able to get this fixed or replaced this may happen again as the same issue occured years ago during a storm resulting in the first monitor breaking. The DVR , monitor and router are all connected to a extension cable. I am to replace the cable with a surge protected one. Any device will be helpful- does one think that this will be enough to avoid this from occurring again?
07.03.21
Hello,
Thank you for replying.
Please see attached images of motherboard. I cannot see any burned out parts , perhaps I am missing something?
Thank you
Jaz
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @pukka ,
Please verify the model number as the number that you posted gives no results when searching for it online?
The monitor would need to be opened and the power board inspected for any damage caused by the outage e.g. burnt out components or blown or bulging capacitors.
If there is any damage then perhaps just the components can be replaced if their value markings are still visible or just simply replace the power board if possible. Search online using the power board’s “board number” (printed on the board itself) to hopefully find one. Sometimes the same power board is used by different brands of monitor but as long as the board number is identical it should work.
Post an image of the power board. Here’s how to do this on ifixit Adding images to an existing question.
With regards to using a surge protector. It is better using one than not using one if power outages happen often.
Be sure to get a “quality” one though even though they are more expensive. By this I mean one that gives an indication that it has operated due to a surge event. This can be either by having a light indicator or perhaps that it doesn’t work and supply power anymore after a surge event has occurred i.e. it has failed and needs to be replaced Some cheaper surge protectors do give protection but only the one time and then continue to supply power after the power has been restored but they no longer have any protection capability and you are unaware of this.
Update (03/07/2021)
Hi @pukka
I can't see anything obviously wrong
The board number is 2202130701P ver.2 (see red highlighted box in image below)
I can’t make out what is written in the green box in the image but using the board number in the red box I found this board.
(click on image to enlarge for better viewing)
I’m not sure if it will work exactly the same with your monitor as perhaps there is firmware in the chips on the board that may alter things.
But perhaps you could use the information I found from the supplier of the board where it showed that it was suitable for a Viewsonic CS10715 monitor and when searching for that I found the schematics for the board on p.68 -69 of the service manual for the Viewsonic monitor.
So you can either use the schematics and try to find the problem or take a risk and buy the board and see if it works in your monitor. The connections on the board are the same. I suppose that you could always contact the supplier and ask if it is compatible with your model also.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Hello,
Thsnk you for replying.
Please see edited part of my original comment dated 07.03.21
I have the images attached
Thank you
Jaz
tarafından
Hi @jayeff ,
Please see my edited part of my original comment dated 07.03.21. I have posted images of motherboard and model details.
Thank you
Jaz
Jaz
tarafından
Yorum Ekle
Yanıtını ekle
Jaz sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 12
Her zaman: 241
