Ana içeriğe geç
Model A1051 / 4 or 6 GB hard drive
90 Soru Tümünü görüntüle
How do you know if the battery health has been deteriorate
Hi I have an iPod mini 2nd Generation. The battery has been holding quite well, I haven’t seen any battery drain yet but I am a bit worried if it doesn’t hold up since it is still an original battery, especially worried on expanded battery
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
You can check the battery stats of your iPod, iPhone or iPad by installing Coconut Battery on yourMac and Hooking up to a USB port and running it.
https://www.coconut-flavour.com/coconutb...
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
It depends on how long have you had this for and how often did you charge and drained the battery. I think when the 2nd gen Mini came out Apple was bragging about the battery which was holding more than double the charge than the 1st gen. I think it is rated for 18 hours audio playback.
Now, since these are quite old device, don’t expect the battery to last that long, but I would imagine it should still hold around 8-10 hours playback, again, depending on the intensity that you have been using your device.
Puan 0
Yorum Ekle
Yanıtını ekle
lincolnchia sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 544
