Ana içeriğe geç
Intel Core 2 Duo T5500 1.66GHz, 512MB RAM, 80GB HDD
Is my laptop's power failure a motherboard problem?
Hello all.
Few days ago my laptop died. The AC adaptor was plugged (and with the green light on) but the battery indicator decreased and finally, the windows low battery message was displayed and finally I shutdown the laptop before the battery was empty.
After that, I tried to switch on without the battery, only with the AC adaptor, but with not successful. When I put again the battery on the laptop then the laptop worked but the battery continued discharging until it was completly empty.
And now the laptop not works any longer. I check the AC adaptor works and a IT professional said me that the problem was the DELL integrated motherboard.
I asked Dell for support and then they said to me that if I want to repair the computer it would cost me $1080 :O
Now I'm asking if there is any way to repair this by myself and where can I found how to repair.
Is anybody lives in Spain and knows any shop where I can repair it is also a good solution.
Thanks in advance.
Regards.
Bu iyi bir soru mu?
Puan 3
3 Yorum
Hi bro, same thing happned wid me, i took me laptop (dell lat-d520) to a very well known place in banglore, SP ROAD(india) heard dat dey can solve any problem, but anyways they screwed my laptop like anything, I learned a lesson not to go anywhere except brand specific service center...
Worst thing is they have stolen RAM, and cmos battery.
I am waiting for my next salary so that i can visit service center or i will not use laptop. Seems internet cafe is an alternate solution.
tarafından
Hi, I am writing from Iran. we bought this series LATITUDE of dell's last year (late 2015) in the United States, and it was working properly for a month. it was perfect, looking good and working even better. yet it suddenly began needing troubleshoots with its power system, that is, it didn't start coming up when I pressed the power button. it was literally DEAD! whether connected to AC adapter or working on battery, it didn't turn on. sometimes the power LED turned on and a black screen was also visible, though the operating system didn't run to show up the windows' logo. most of the time this very initiation step doesn't happen either and 'nothing' reacts when I press the power key. I have been asking people have a look at its power system. they either refused or said it is already working properly. yes, they told the truth, actually. it is working properly as we speak, but if she decides RIGHT NOW out of WHIM to rest for a while, then it won't turn on again until it wills to
tarafından
I have this problem too. I reinstalled windows and then reseted windows. After it restarted, it would't load windows. I had windows 10. It was dell latitude e6400.
tarafından
Yorum Ekle
6 Cevap
Filtre ölçütü:
Seçilen Çözüm
It sounds like your problem is the DC-In board. Unfortunately, I do not know if that is integrated with the mother board on Dell computers or not. If it is, you will probably need to replace it. I'll bet you could find a replacement for significantly less than $1000, but I'm unaware of any websites with repair guides for these computers. I wish I could be more help!
Bu yanıt yardımcı oldu mu?
Puan 5
Yorum Ekle
If you have a multimeter you should be able to check the output of the power supply. If the output from the power supply is good than it is probably your battery. If I remember correctly the battery had to be installed to power up the laptop even with the power supply.
Puan 2
Yorum Ekle
My latitude 100L making same problems, it works from battery, but not from AC-adapter. Adapter is OK, problem is on the motherboard, I checked with oscilloscope - PWM controller (ISL 6247) on the motherboard give power for short time and for unknown reason, interrupt supply of power. So, I will play a bit again with this laptop, and if it will not work I will probably replace motherboard. Check on ebay, it could cost around 40$.
Puan 1
Yorum Ekle
One thing to check would also be the power cable from the adapter to the computer. If there's a physical break in that line it would result in the same issue, slow battery decline and failure of power. Find another AC adapter and see if it works. If that still fails, then Tyler's advice stands.
Puan 0
Yorum Ekle
Motherboard problem it can’t boot if it tone on it will tone off what might be the problem
Puan 0
Yorum Ekle
Check your battery if good .
Puan -1
Yorum Ekle
Yanıtını ekle
escuriola sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 30,250
