Ringtone volume low and on call crackling
Ringtone volume is very low. On call it is very quiet
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Clean out all the speakers on the device with a toothbrush and some alcohol, and check the quality of sound then. Try going into Settings > Sounds and Haptics, and dragging the Ringer and Alerts slider around a bit to see if it changes the volume of the ringer.
If nothing else seems to be helping and you’ve tried factory resetting the device, perhaps take it into a service store for a diagnostic or if you’re able to yourself, replace the earpiece speaker and see if the quality of audio coming through on calls improves.
Bu yanıt yardımcı oldu mu?
The issue is Face id is not working. I think it is an earpiece replacment via soldering
@Hisham Atcha Ahhhh, was the screen replaced or the front camera assembly? When did FaceID stop working?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 81
4 Yorum
Do you know if the person on the other end of the call can hear you well? Also have you cleaned out the earpiece grille?
Is this just happening on the earpiece speaker or on loudspeaker too?
Liam tarafından
is the earpiece in charge of ringtone
Hisham Atcha tarafından
I think it is only only when making and receiving cals
