Ana içeriğe geç
Updated Apple TV with second generation A5 processor / Released March 7, 2012
32 Soru Tümünü görüntüle
It's not discovering any wifi or even bluetooth. (Apple TV 1427)
My Apple TV 1427 is not discovering any wifi or even bluetooth. Tried after updating software with direct cable connection. Even then it is not working. Reset, restored and software update, all tried but to no avail. Kindly let me know what could be wrong and how to solve it. Thank you.
Bu iyi bir soru mu?
Puan 0
4 Comments
Do you have the ability to open it up?
tarafından
I will be happy to try. Thank you.
tarafından
Right now as a last attempt, I've connected it to MacBook Pro and started restoring/updating it. I'll post the result once I'm done.
tarafından
I've done restore/update through connecting to iTunes n MacBook Pro. But this has also not helped. It appears it is a hardware issue. Kindly help me. Thank you.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Sadly, there’s not much you can do here.
Clearly your logic board has failed so you’ll need to find someone with the needed skills to fix it, if that is possible. The problem is the cost of a new unit is likely cheaper than either finding another logic board or the cost of repairing if that’s possible,
Review this Apple TV 3rd Generation Teardown as well as Apple TV 3rd Generation Logic Board Replacement
Apple TV 3rd Generation Görseli
Kılavuz
Zorluk:
Orta
Apple TV 3rd Generation Logic Board Görseli
Kılavuz
Zorluk:
Orta
10 - 15 minutes
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Thank you so much for sparing your valuable time.
Let me use it as a paperweight!!! That's the only option left now!
tarafından
Yorum Ekle
Yanıtını ekle
Venkat sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 54
