Ana içeriğe geç
Model A1989, EMC 3358. A refresh of the existing design, with updated processor options and a change to the keyboard materials. Available in Silver and Space Gray. Released in May 2019.
133 Soru Tümünü görüntüle
MacBook screen blue (no apple logo) after replacing bezel front trim
So I had replaced the bottom strap on screen (where name of MacBook is) and now my MacBook switches on to dark blue screen. No logo, no chime, no nothing on screen, caps lock works. What could be wrong. Did I over heat anything? Nothing seems to be broken nor ripped from "ribbons" at the bottom of screen, I just can't get it to load regular screen. During process of heating the aeria I saw laptop booted and screen was while with login, flickering and came back to colored and normal so I switched it off and finished and now nothing.
I tried reseting Command+Option+P+R keys together nothing.
Any help and hints much appreciate it.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Ouch! Sounds like you were a bit aggressive with the heat gun and/or damaged the cables. The T-CON board is very close to the hinge area as you can see here.
Sadly, its time to replace the full display assembly MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement
Bu yanıt yardımcı oldu mu?
Puan 0
4 Yorum:
Any other solutions to try before taking it apart? Seem I have 2019 pro with touchbar .Any other ideas even if low percentage of success rate?
tarafından
@absolutelyfabfad - OK so you elected the wrong system, I'll fix that. Sorry no magic ;-{ You need to replace the display.
Here's the proper part for your system 13" MacBook Pro Complete Display - Space Grey and the guide for it MacBook Pro 13" Touch Bar 2019 Screen Replacement
tarafından
Do you guys think apple would be able to replace just the T-CON Board or also will they go for whole LCD?
tarafından
@absolutelyfabfad - Apple will only replace the full assembly, which includes the T-CON board as that is hardwired to the LCD panel.
tarafından
Yorum Ekle
Yanıtını ekle
absolutelyfabfad sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 161
