Why can't I hear incoming calls (except on speaker or earpiece)?
I have a iphone 6s Plus, earpiece and speaker work, but I cannot hear incoming calls unless through the earpiece or speaker. Which of the phone microphones need to be replaced?
Bu iyi bir soru mu?
I may be a bit confused here but if not through the earpiece speaker or the loudspeaker, where do you want the sound to come from??
Liam tarafından
When you're saying microphone, do you mean that nobody is able to hear your audio on a call or do you mean the speaker that makes sounds. I believe you mean that your loudspeaker works fine and audio can come through headphones, but won't work on the earpiece speaker at the top of the phone when on a call?
Liam tarafından
Yes, thank you, that is correct, Liam.
Avrohom Teichman tarafından
