Ana içeriğe geç
Technique for replacing belt
Have this Hilti DSH600X power saw. Been trying to replace the drive belt . It's a serpentine belt. Been trying to heat it in hot water so i can stretch it enough to roll over the front blade pulley. Just can't do it. Wondering if there is an easier method? Can't find any adjustment screws or slide. Anyone know about this?
Thks, Charles
Bu iyi bir soru mu?
Puan 4
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
I did two of these belts I used long 3/8 extension One end of the extension on the pulley nut with the belt on extension and stretch You got tie the saw down so it won’t move you really got to stretch the belt
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
So pretty much, Hilti wants you to send tool into them to do any maintenance.
tarafından
Thank you I will try that!
tarafından
Yorum Ekle
Think about this. The mfg put it on with ease, you should be able to also. The has to be an adj since belts stretch.
This is for a Stihl but I am betting it is similar https://www.youtube.com/watch?v=a7cydlI8...
Or you could go here and chat with Hilti customer service https://www.hilti.com/content/hilti/W1/U...
Puan 0
Yorum Ekle
What is the belt number that fit the dsh 600x concrete saw
Puan 0
Yorum Ekle
Yanıtını ekle
Charles Goossen sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 38
Her zaman: 2,186
