Ana içeriğe geç
Repair and disassembly information for the 2020 refresh of the MacBook Air model A2179 with an Intel processor that was released in March 2020.
101 Soru Tümünü görüntüle
MacBook Air 2020 - startup key combinations not working
Hi, I lost the right arrow key.
Now I can't use the Mac startup key combinations like recovery (CMD + R).
How to solve this issue ?
Apple helps me to replace single key? or Arrow Keys alone ?
Laptop Details :
MacBook Air (Retina, 13-inch, 2020)
1.1 GHz Dual-Core Intel Core i3
8 GB 3733 MHz LPDDR4X
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
While loosing the arrow key does need to be fixed in its self it shouldn’t stop you with the startup keys. This sounds like a deeper issue here, did you leave the T2 secure boot feature enabled? About Startup Security Utility
You will need to disable it and/or you have still deeper issues with the keyboard which will need to replace it MacBook Air 13" (A2179, Early 2020) Upper Case with Keyboard
Reference: About macOS Recovery on Intel-based Mac computers
MacBook Air 13" (A2179, Early 2020) Upper Case with Keyboard Görseli
Ürün
$249.99
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Thanks a lot for your valuable answer.
I have doubt, if its keyboard issue? How it works fine after login.
After I logged in, I face this issue sometime "Like I selected the icon and keep moving to the right side" I use the ESC button to overcome.
I can't enter into the recovery mode.
tarafından
@iamjayakumars - If its not the keyboard, then its the trackpad and its combo cable or worse! Your logic board.
tarafından
Yorum Ekle
Yanıtını ekle
Jayakumar Sadhasivam sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 124
