How do I remove a stripped heatsink screw?
I am trying to remove one of the heatsink screw, but unfortunately it has been stripped, and is too stubborn to unscrew too. How do I remove it?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
You do need to be careful here as the studs are only glued onto the logic board and can easily snapped off!
I would first see if some solvent will release the thread lock that’s holding the screws onto stud. Then I would try heat from a heavy duty soldering iron as you need to heat things up quickly and a larger mass iron will do this over a small pencil type.
Bu yanıt yardımcı oldu mu?
Oh! need to try it. Thank you. :)
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 44
