My MacBook won’t turn on, sometimes
Hey,
I have a late 2013 13” Retina MBP, everything was working totally fine until the trackpad completely died, I used it like that for a bit and then whenever you touched the trackpad the keyboard would stop working until you stopped touching the trackpad, anyway that’s not the point I just said it because it may have something to do with this.
Now it’s doesn’t turn up sometimes, no fan, no chime, nothing, but if you leave it for sometime and then try again it boots up and works just fine, well with all the listed above, I thought that I could be the keyboard but I tried with the power pads, disconnecting the keyboard and battery and plugging it in and nothing I don’t know what else to do,
I’ve reset the SMC, the NVRAM, Diagnostics are fine apart from keyboard and Trackpad, it just like dies and whenever it wants comes back to life.
Also sorry for the long post
Bu iyi bir soru mu?
Given your systems age let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
I'm thinking your battery needs replacing.
Dan tarafından
@danj hey, yes I already have it it had like 650 cycles, I disconnected the battery and it worked if you plugged the MagSafe in, it started and then you shut it down plug it in again it worked but if you leave it sometime off it won’t boot up again
Daniel R tarafından
@danr28 - please post the screenshot so I can see it.
Dan tarafından
I removed it, it was in poorly condition anyway, I can’t post the screenshot because it doesn’t have a battery @danj
Daniel R tarafından
