Ana içeriğe geç
Repair guides and support for the random-access memory used in computers.
45 Soru Tümünü görüntüle
Two RAMs not working together
So my two DDR4 RAM which are same in everything, used to work together before, but all of a sudden they are not working together.
The RAMs do work individually but don’t work together, they both are 8GB.
I know that the slots are working as I tried changing them and putting them together.
Bu iyi bir soru mu?
Puan 6
1 Yorum
What is your system? Make and model.
Depending on what you have you may need to use a different set of slots (Banks Vs Channel).
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Make sure that your motherboard’s BIOS is up to date, along with any updates for your operating system. Also, look at each RAM stick individually to make sure that they are indeed exactly the same. If one of them looks inferior for any reason, you could consider replacing it. My laptop has a cheap factory 4GB SDRAM stick and a better 8GB SDRAM stick that I purchased as an upgrade. They both work together, and it doubled my laptop’s speed while enabling more browser tabs, etc. to be open at the same time. Get to know your computer’s motherboard, it’s capabilities, your RAM details, and any drivers or software that could be useful. Good luck! I hope this helps.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
En Yararlı Yanıt
Make sure you have in them in the correct slots,
if there are 4 slots, do 1 and 3,
I think
Puan 2
Yorum Ekle
Try changing the slots by putting one ram card in a different slot....that way it might work
Puan 2
Yorum Ekle
Check bus rate should be same
2400
2666
3200
Puan 0
Yorum Ekle
Yanıtını ekle
Hadi Imran sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 89
Son 30 gün: 324
Her zaman: 9,809
