Ana içeriğe geç
The Surface Laptop by Microsoft is the first full laptop in the Surface lineup. Released June 2017. Model number: 1769.
33 Soru Tümünü görüntüle
Part of theSurface Laptop touch screen does not respond to touch?
A 1 inch wide portion from top to bottom on the right half of my Microsoft Surface Laptop does not respond to touch. However, the mouse works just fine and there is no problem to the other area as they respond to touch.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Does the screen have any cracks or big scratches in it? One thing you may be able to try is run the Windows 10 calibration utility. Open the start menu and search for “Calibrate”. One of the options that should pop up is “Calibrate the screen for pen or touch input”. Select that and then click the “Calibrate” button in the Window that shows up, then select “Touch Input”. Select “Yes” to the UAC prompt and the calibration tool should pop up with instructions. If you get to the bottom portion and still can’t continue, you can hit escape to leave the tool.
If calibrating the display doesn’t help, my bet would be that there is an issue with the digitizer. Unfortunately this model has earned a 0/10 for repairability for a good reason. It is basically impossible to get into this thing without destroying parts of it. If you do attempt repairs I wish you the best of luck.
Edit: Fixed some spelling.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
akhil manuel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 15
