Can. Audio be repaired sounds static
static sound from tv speakers,even using optic out to LG sound bar
Bu iyi bir soru mu?
Bu iyi bir soru mu?
raymond mancino that sounds like a bad audio IC. Those are usually located on the main board. Since we do not know the model of your TV etc. I suggest that you start looking at the main board and check for obvious damage. The only other things you can try is a quick reflow of the IC or replace the main board and see if that makes a difference. Of course, make sure that your speakers are okay and the the wiring is ok as well.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 69
