My lower burner has quit heating.
Can this be repaired by replacing the heating fuse.?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Could be a fusible link. Could be the heating element itself. When I replace one I normally replace the other at the same time, if the equipment im working on has both. Check and see. You'll have to open it up. Disconnect both ends of the element and do a continuity check. If no continuity then it's a ad element
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 8
Her zaman: 372
