Portable Monitor Screen Replacement
I have a (fairly new) Asus MB16AMT touch portable monitor. I’m seeing a lot of broken displays in reviews and can’t find a replacement display matrix. Mine cracked in the first 3 weeks because the stock case lets it fall over easily. The housing is extremely easy to open.
Display model is: B156HAK02.0 but all I can find is the “40 pin narrow (16mm)” connector version (need the 20mm 40 pin connector)
Asus portable monitors should be added to this fix library, I think they would easily score a 9 / 10 on reparability if you can get the parts! Does anyone have a source for this display?
Bu iyi bir soru mu?
7 Yorum
Did you manage to successfully repair your screen Darren? Would be interested to hear how you got on and whether worth having a go at my own (similar) Zenscreen.
When you say the housing was extremely easy to open, how did you go about it? Would be great if you could post up a simple guide!
asemblance tarafından
It's all fixed. It's actually a very easy repair. Take your time on the perimeter bezel latches. But there was no glue strips to fight.
The correct part is very hard to find. Be very careful which you get. Asus used several different motherboards and display connectors. Plus the display matrix is used in many PC's with various connectors. Only purchase one with an exact model number match.
Darren Gladstone tarafından
I had a similar accident yesterday and I'm looking to buy the replacement screen. I can attest to how easy it is to remove the bezel. It's all about getting your thumb to pull the inner edge up while pushing with your other fingers down on the outside edge. Hopefully I can find the part a successfully repair this great accessory.
Ricardo Halfeld tarafından
How can i contact with you?
Aziz tarafından
I'm glad to hear they are easy to open. I have a similar (non-touch) MB16AP I am going to give a go at repairing.
I would love to see a guide published. My issue is "no power on", hoping it is just a bad solder joint on the USB-C or loose connector.
I'll post the display part info for the non-touch after I get into it.
clickykbd tarafından
2 tane daha yorum göster
