Ana içeriğe geç
Released alongside the AirPort Extreme base station, this hard drive equipped variant offers 802.11ac speed on a time capsule NAS.
56 Soru Tümünü görüntüle
Airport Time Capsule Wireless 5G stopped working, can it be fixed?
I’ve tried rebooting, resetting, and disconnecting power for 3 minutes and reconnecting, downgrading the firmware and upgrading back to current: nothing brings back the wireless 5G. Is this something that can be repaired?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
So I talked with apple support, after walking through settings in Airport Utility, it was discovered the 5Ghz network name was deleted or broadcasting as the same name as the 2Ghz (which won’t work). After re-adding a 5Ghz name, it’s broadcasting as normal.
This can be found under the Airport Utility -> Device -> Edit -> Advanced -> Wifi settings -> 5GHz Name.
https://support.apple.com/airport/repair...
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
En Yararlı Yanıt
Your AirPort only offers WiFi 802.11 a/b/g/n/ac compatibility.
It does allow 2.4 GHz and 5 GHz band access simultaneously
5G is a term for cellar transmissions which your WiFi Router does not offer.
Here's a useful reference: Different Wi-Fi Protocols and Data Rates
Puan 1
3 Yorum:
Yes, my post is not referring to 5G wireless, I’m referring to 5 GHz band. The question is: can this be fixed to do I have a 2 GHz door stop?
tarafından
@ian_mcclain - Are you sure the 5.0 GHz band logic is bad?
You may want to get some diagnostic software like WiFi Explorer Lite it will allow you to see your routers bands.
Often I find your laptop gets locked in to a band. Try clearing your WiFi cache. I also find altering the routers AP names helpful! Rename the bands to ACHME_2-4 and ACHME_5-0 (use your own names here) so you know the band you are connecting over.
tarafından
The band has a unique name. It functioned without issue for 5 years and stopped working for all devices on the network. The 2.4 band is still working.
tarafından
Yorum Ekle
Yanıtını ekle
Ian McClain sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 13
Her zaman: 939
