Ana içeriğe geç
2.26 or 2.4 GHz / White plastic unibody enclosure
645 Soru Tümünü görüntüle
silence when I reboot into High Sierra
Have the same problem on a 2010 white plastic macbook running high sierra.
Nothing I found on line worked. Then one day I booted it from a Linux Ubuntu install USB stick and the sound worked fine all the whie that OS was booted so mine is not a hardware problem.
It went back to silence when I rebooted into High Sierra. Does that tell anyone here what needs to be fixed on mine? thanks djc
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
Did you try a smc reset
tarafından
Once a day for weeks
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Apple killed the startup Chime on you! Here’s more on it How to resurrect your Mac’s startup chime
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Chime always worked but no sounds afterward.
tarafından
Lets clarify things your issue is not the startup chime, its your lack of sound after boot (no music, podcasts or videos) is that correct??
tarafından
Yorum Ekle
Yanıtını ekle
djcopely sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 35
