Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
6 Yorum:
Is it only during acceleration? Have you tried fuel treatment to clean the system? Could potentially be motor mounts as well. Pop the hood n fire it up. Have someone put it in drive, and reverse. Does the motor look like it moves when you do?
What is the year/make/model? It sounds like a CV joint is going. Do you hear clicks or thunks when making sharp left/right turns? CV joints are known to cause vibrations when accelerating
brandon k tarafından
I did the fuel treatment for several tanks and nothing has changed. I'll look at engine and check it out. It's a 2017 canyon and this on
Y happens after speeds of 40 and above.
Ed Olson tarafından
2017 canyon, no noises at all just vibrates when accelerates. Really notice it in cruse control. On and off.
Ed Olson tarafından
Definitely sounds like cv joint. Check them to see if the boots are damaged. If they are... time to replace. https://axleaddict.com/auto-repair/Car-V... should help.
1 tane daha yorum göster
