Ana içeriğe geç
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 Soru Tümünü görüntüle
Upgrading from core duo to core 2 duo: which cpu to get?
Hey guys,
I have been looking to upgrade the processor in my imac since lion came out but im not sure which intel model i need.
My system profiler on my imac shows the following:
Hardware Overview:
Model Name: iMac
Model Identifier: iMac4,1
Processor Name: Intel Core Duo
Processor Speed: 2 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 2 MB
Memory: 2 GB
Bus Speed: 667 MHz
Boot ROM Version: IM41.0055.B08
Which core 2 duo cpu do i need in order to successfully upgrade my imac? Im happy with a 2.16Ghz core 2 duo cpu, i dont know if i can get a higher cpu for my imac?
I have seen some members who have upgraded their imac to a core to duo but i didn't see which c2d cpu was used.
All help is greatly appreciated.
Bu iyi bir soru mu?
Puan 1
4 Yorum
Is this the one i need
Intel Core 2 Duo T7400 2.16 GHz 4M/667 SL9SE
tarafından
Cellers - Please look over my links, your information is not correct as I have done it. BTW I've tried without success to download the Beta 8 times without success to solve the install problem on the Core Duo processor.
tarafından
mayer you have also said that you have not got a stable running install of 10.7 Lion, in a comment that you have since erased here: Installing 10.7 onto a CoreDuo MacBook
tarafından
I got the first retail version of 10.7 to install on an 1.83 Core Duo to a 2.16 Core 2 Duo CPU upgraded 17" iMac.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Here's my post with links on upgrading the CPU: change MacBook Pro cpu from core duo to core 2 duo
Here's my original post on the Lion installation question: Will Macs upgraded to Core2Duo Processors work with Lion?
I used the retail version of Lion as I didn't have the Beta.
Bu yanıt yardımcı oldu mu?
Puan 4
2 Yorum:
The 2.16 GHz is a T7400, M socket. You can probably take it to a 2.4 GHz T7600, M socket.
tarafından
Thanks for the replys, i have found the t7600 c2d 2.33ghz cpu, it has the same 667mhz fsb as my current one so it should work
tarafından
Yorum Ekle
you can put a 2.16 or 2.33 Ghz C2D cpu in that machine. i upgraded mine to a 2.33 with help from mayer and others on this site.
Puan 1
Yorum Ekle
Hi to everybody.
I'm new on this forum, but I tried this site very helpful! Thanks to your guides, I could make many works on my Macs.
About your question I could say that: the T7400 processor (2,16 Ghz) could be firstly replaced by a T7600. Infact, Apple itself selled upgraded iMac with T7600 instead of T7400.
But I have a further question: is possible the substitution of the T7400 or T7600 with a more powerful processor (a same family processor, a Merom mobile processor, obvious!). How I can try a table, a list, with compatibility of various models of processors?
For example, I examine the list on Wikipedia, but I think it's not sufficient: Apple community support is very incompetent, unqualified (they repeat that the cpu is soldered on motherboard, for example, and nobody could replace a cpu. Only to buy a new mac is the option).
In general, I would be interested to know a "place", a website or something to control a list of compatible cpu upgrades, not only for a specific cpu (or pc) model.
Many thanks for your work!
Best regards!
Puan 0
Yorum Ekle
Yanıtını ekle
Dipak sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 17
Her zaman: 3,431
