Ana içeriğe geç
25 Eylül 2015'te yayımlandı. A1688/1633 modeli. Bu cihazın tamiri eski nesillerinkine benzer; tornavida ve kaldırma aletleri gerektirir. GSM ya da CMDA olarak / 16, 32, 64 yada 128 GB kapasiteli / Gümüş, Altın, Uzay Grisi yada Rose Gold (Gül Altın) seçenekleri mevcuttur.
2690 Soru Tümünü görüntüle
iPhone won't charge after battery replacement (red battery icon)
I just bought an new battery but it wouldn't charge after the replacement. I've tried replacing my old battery and it works just fine. The new battery only shows the red battery icon after plugging the charging cable, and won't turn on the phone.I tried measure the voltage but it's normal (3.82v), is there any solution for this?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
If the original battery still lets the phone power up, then it seems like you received a faulty battery. Contact whoever you got the battery from and see if you can get a replacement.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Thanks for replying, I had contacted the seller, still waiting for the reply.
My phone just turned on after 1 night of charging, but it suddenly turned off after I entered my password (2% of battery).
I also want to know the reason why does it charging so slow. Voltage of the battery seems normal( stable 3.82V), and the charging cable, adapter works fine either, so could it be the battery IC failure?
tarafından
@linsyun Faulty batteries can do all sorts of weird things, I would guess that is related.
tarafından
Yorum Ekle
Yanıtını ekle
syun sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 29
