My tv screen has just start going black but I still have sound
I can’t find the power button on the tv to reset it
Bu iyi bir soru mu?
Bu iyi bir soru mu?
You need to do a flashlight test, Turn it on and hold a flashlight up to the screen. If you can see an image then either the power supply board or the backlights are bad.
If you see an image then disconnect the cable going from the power supply board to the main board, If the back lights come on then you need to replace the board. If not then its most likely the backlights need replaced.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 124
3 Yorum
What is the model of your TV? If you shine a flashlight on the TV screen while the TV is on, do you see a faint picture?
Andrew S tarafından
can you please tell is what device(s) you are attempting to use your TV with
[deleted] tarafından
Hi, in my case I can see a faint imagen when pointing a flash light to the screen anda I can perfectly hear the sound
Mauricio tarafından
