Ana içeriğe geç
In June 2017 Apple updated its 13" MacBook Air with a newer Broadwell Intel Core i5 processor, resulting in slightly increased performance and battery life.
310 Soru Tümünü görüntüle
MacBook air 2017 not turning on.
My Mac is not turning on. When I switch on the laptop the fan rotates for 2 seconds and then stops. Nothing else happens. I have tried removing the battery and run it on adapter. But the same result.
Also when battery is connected, there is no light on the adapter. But when battery is removed, the adapter light is on.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Try disconnecting the trackpad flex cable from the main logic board (shown in Step 23 of this guide). With the cable and battery disconnected and the bottom plate removed, open the display and set the machine on its side with the MagSafe 2 port facing upward. Then connect the MagSafe charger and press the power button. If it’s able to power on the issue may be due to a failing trackpad flex cable or a failing trackpad.
If that doesn’t help, you’ll need to do some further troubleshooting with the I/O board and the logic board as the point of failure probably involves one of those two components. Hope this helps!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
tuhin chakrabortty sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 13
