Ana içeriğe geç
Repair guides and support for networked security cameras, smart home monitoring cameras, and Wi-Fi connected cameras.
103 Soru Tümünü görüntüle
Need help identifying RJ45 ethernet replacement part.
I need a part number or a link to the proper RJ45 modular connector.
my device is a unifi protect g4 dome model number UVC-G4-DOME
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorumlar:
I also need to replace this port, where were you able to find a replacement for this port/module
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @gizmowizards ,
Don’t know the answer but have you tried scanning the QR code on the bottom of the connector as shown in the 2nd image above to see if that gives any further information?
Alternatively try searching here or here with the RJ45 parameters that you know e.g. 6 pin or 8 pin, through hole etc and then check the data sheet of the more likely ones to see if they are compatible with mounting on the circuit board.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Randy Northrup sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 113
