Fake charging - I give up :(
Hi all
I have an iPhone 6 Plus that I’m battling with (and losing badly), that has a charging issue. The phone recognises the charger and shows the charging symbol, but the battery does not charge and battery % does not change. The amp meter shows quite an unstable amp reading constantly changing and ranging from 0.25amps to 0.6amps. When the screen goes to standby/inactive the reading drops to almost zero amps.
I have all the correct diode readings on the dock connecter. I get 3v on PP3V0 Tristar. When I connect a charger with no battery connected I get between 3.8v to 4.2v on PP_BATT_VCC. I’ve tried the board with a known good charging port and battery, unfortunately I still have the same issue.
I started with replacing Tristar/U1700 as I find this solves the issue in the vast majority of cases, however not this one sadly :(, I’ve also replaced Tigris/U1401 and Q1701, however I still have the same issue.
Here’s the interesting part, I decided to replace the MOSFET Q1403, before doing so I bridged PP_BATT_VCC & PP_VCC_MAIN (with Q1403 removed). This solved the problem, the battery charges normally and the amp meter shows a more constant 0.8amps whether the screen is active or not. I thought I’d cracked it at this point and replaced Q1403 with a new one (well from a donor board). Unfortunately the same issue came back with the replacement of Q1403.
I’m completely baffled now, any ideas anyone? I will be greatful of any thoughts as always :)
Bu iyi bir soru mu?
Does 3utools show battery data?
Chris Stables tarafından
Just thinking on top.of my head, but I'm just curious to know if you have concidered the PMIC?
Innovatrix Repairs tarafından
@imicrosoldering
Hi Chris, I think you're on to something! 3Utools doesn't show battery data. You've put me on the right track, after researching this a little I've now downloaded the iDevice Panic Log software, this suggests the issue maybe with the vibe driver or BATTERY_SWI line. I've now replaced U1400 but unfortunately I still have the same issue. I'm now focusing on the BATTERY_SWI line, I've noticed there is a 'Filter' on this line FL2511, however the strange thing is I don't get continuity across this but I also don't on a known good board, I also get the same diode readings 0.595 & 0.495 on each side of the 'filter' which is the same as a known good board, but not continuity. I've seen some fixes using jumpers and resistors under Tigris?
Darren tarafından
@innovatrix Hi, thanks for your input, I haven't considered PMIC so far, but now I seem to have tried everything maybe it could be something to do with PMIC. I really don't think I'm minded to replace PMIC to find out, as it's not really worth the repair.
Darren tarafından
@imicrosoldering My curiousity always gets the better of me in these situations, I should know when to give up from a time/value perspective lol, anyway I've now gone ahead and tried both of the Tigris/U1401 jumper/resistor options I can find. One by running a jumper from pin G1 to a 2.2k resistor, connecting the other side of the resistor to ground, then a second resistor on the same jumper, connected to G1 with the other side connected to VCC main. I can't explain why I've tried this other than I seen someone do it on Youtube lol. I've tried a second jumper from FL2511 (BATTERY_SWI_CONN) to a 2.2k resistor with the other side connected to PP3V0_TRISTAR - neither of these have made any difference :o
Darren tarafından
