Ana içeriğe geç
Repair guides and troubleshooting for the Whirlpool Quiet Partner II insulated dishwasher.
How do I reset my Quite Partner II Dishwasher
My Quiet Partner II dishwasher is not working - the control panel is no longer lit up. I am having a difficult time trying to find out how to Reset it with the correct control panel button sequence for this model. I believe it is hard-wired so I have checked the breakers in my basement. I have pushed some buttons and the lights came on and off but not working. and When I push the cancel button it comes on -:O) instead of the start button and the washing selections. Help! :O)
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
9 Yorum
Hi,
What is the model number of the dishwasher?
tarafından
Model #Du1055xtvq8
tarafından
Hi @stihl209
Did you try the Most Helpful Answer below, you didn't say?
tarafından
I have power to the unit but no lights. Model DU950PWKQ1. I tried the reset as described with no success
tarafından
Serial # FY 1421120
tarafından
4 tane daha yorum göster
Yorum Ekle
8 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Judy Doughty some of this will depend on your DW exact model. In general to reset the Quiet Partner II you:
Open the DW door
Push "heated dry," "normal," "heated dry" and "normal" in quick succession. immediately after this close the dishwasher door.
Bu yanıt yardımcı oldu mu?
Puan 18
28 Yorum:
Thank you it worked. Dishwasher is up and running. DT
tarafından
@daybreak1964 good job and thanks for letting us know!
tarafından
It didnt work for me .. Any other ideas ?? Please
tarafından
@Wanda Reddick
tarafından
I had success with pressing both buttons at the same time, twice. Then closing the door. I may have even closed the door as I was pushing the buttons for the 2nd time.
tarafından
23 tane daha yorum göster
Yorum Ekle
Turn off the power. Open the dishwasher, take out the top 6 screws. The top control panel should pull away from the dishwasher. Pop off the plastic cover inside to expose the circuit board. Disconnect the 14 or 16 pin ribbon cable. Turn the power on. With the power on, carefully reconnect the ribbon cable. Reassemble your dishwasher. My dishwasher works again for me!😀
Puan 3
5 Yorum:
The pin ribbon cable approach worked for me. Thanks very much
Used a Torx 10 bit to remove and tighten the screws.
Pressing buttons in different manners hadn't been successful
According to dishwasher's serial number and information I obtained from the Internet, the Quiet Partner II was manufactured in 2010.
tarafından
The pin ribbon cable worked for us!
Pushing the buttons did not work for us.
Thanks
tarafından
I popped open the cover, the ribbon pin was permanently attached and I couldn't remove it. I jiggled it and a couple of other connections, cleaned up a bit and closed it up. Now the dishwasher is working again! The only issue is that on the left side, the Pots&Pans, Normal, and Light lights remain dimly glowing even when the DW is completely off. I never noticed this before. Is this a normal thing, or is it something for me to be concerned about?
tarafından
Don’t do this. My dishwasher is now completely broken and will need to be replaced
tarafından
It worked great for me ! Thanks ☺️
tarafından
Yorum Ekle
Puan 1
1 Yorum:
I have a whirlpool gold DW model # GU1500XTKT0 not operating and have a constant flashing rinse only light. Any ideas that I may try?
tarafından
Yorum Ekle
Normal wash, light wash and off/reset lights are flashing at same time. No other buttons will work.
Puan 0
2 Yorum:
This worked for me as well! Thank you!
tarafından
Same issue here! I turned the breaker off and pulled the chipboard out unplugging it completely, put it all back together and it worked just fine!
tarafından
Yorum Ekle
My dishwasher is flashing on the normal wash and will not come on
Puan 0
2 Yorum:
Same issue here! I turned the breaker off and pulled the chipboard out unplugging it completely, put it all back together and it worked just fine! Sometimes just turning the breaker off for 30 seconds will reset it.
tarafından
I posted same issue above but now see you have dealt with this already. Is the CPU board behind the inside door panel? Removing i think 14 screws will allow me access?
tarafından
Yorum Ekle
I’m just getting all lights on with no response to any button being pushed after doing the heated dry/normal push reset. Any ideas what could be going on?
Puan 0
1 Yorum:
Hi,
Have you tried disconnecting the power to the dishwasher for 5 minutes and checked if that reset it?
tarafından
Yorum Ekle
My dishwasher is blinking right now and won't work! Help!
Puan 0
1 Yorum:
Hi @jonathanbutz
What is the model number of the dishwasher and which light(s) are blinking?
tarafından
Yorum Ekle
Pushing these buttons together at the same time and holding them for around a minute or two was what worked for me.
Puan 0
Yorum Ekle
Yanıtını ekle
Judy Doughty sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 25
Son 7 gün: 188
Son 30 gün: 793
Her zaman: 49,459
