Ana içeriğe geç
Model A1347. Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
What's the maximum supported CPU?
So I’m now the happy owner of a mac mini with an actually physically broken CPU, and I was curious what was the maximum CPU that would work in it? Any unsupported higher performance ones? Or just the one Apple put in? Thanks!
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
To start things here be aware the Mini’s use a soldered CPU chip unlike 27” iMac’s (and only some 21.5” iMacs).
So you’ll need to replace the logic board assembly to properly repair this system. Mac mini Late 2012 Logic Board Replacement
As far as what are your options you are limited to what Apple used
  • 2.5 GHz Core i5 (I5-3210M)
  • 2.3 GHz Core i7 (I7-3615QM)
  • 2.6 GHz Core i7 (I7-3720QM)
So why can’t I solder a new CPU chip: Given the number of solder pads (BGA) involved here you really need a proper chip rework station to preheat the logic board and lift the old chip off and then the reverse properly heating the chip and board as one of the killers is solder pad shear when the chip and logic board shrink at different rates causing the joint to fail. This gear is not cheap and there is an art to it as well. Unless you’re working with lots of boards its not worth it.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
I know about BGA rework stations, but I thought it could be a fun experiment anyway, thanks for your help!
tarafından
Yorum Ekle
Yanıtını ekle
Nar001 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 17
Her zaman: 1,107
