My Xbox randomly turns off while playing after 20 minutes.
My Xbox randomly turns off while playing after 20 minutes. I used compressed air to clean out the heat syc
Bu iyi bir soru mu?
Bu iyi bir soru mu?
have you dusted and cleaned it out? it probably is over heating
Bu yanıt yardımcı oldu mu?
I cleaned it out with a brush and a vacuum and with compress air. Power cord is plugged into a extension cord.
is the fan working?
also when you cleaned it did you remove the main board and look at the bottom?
This was a common problem when the console released and had to do with the power cable's ability to be inserted either way. Try unplugging the power cable from the console flipping the cable over and inserting it that way.
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 223
