Ana içeriğe geç
Part of Google's third generation of Pixel phones, the 3a is a budget-minded option with the same camera as Google's flagships. Available in Clearly White, Just Black, or Purple-ish. Released May 2019.
62 Soru Tümünü görüntüle
Black screen - Does't open after replacing with new battery
Followed scrupulously the ifixit guide to replace the battery in my google pixel 3a, everything went very well. After the replace, before gluing the screen, I charged the battery in order to check if the replacement works, to my surprise the charging percentage didn’t appear on the screen, even after an hour or so. Tried to put the phone ON, nothing. I disassembled the phone, checking for a loose connection, everything is fine … When the phone is plugged in the charger, it gets warm, but doesn’t open, screen dead … Anybody as an idea of what is wrong? Thanks!
Paul
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
2 Comments:
This malfunction is common in some iPhone models, you must make a software for the mobile and it will return to work again But before that, make sure that you have installed the monitor cables correctly, taking into account the disconnection of the battery before installing the monitor.
tarafından
Have the same issue, must've reseated everything over 12 times that I broke my proxy sensor cable eventually, the screen still won't power
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
You must first reinstall the screen and make sure that all its filters are connected with the installation care and you disconnect the battery. If the attempt did not succeed, make a software for the mobile, as this is a common malfunction for some iPhone models.
Bu yanıt yardımcı oldu mu?
Puan 0
3 Comments:
Hi Ahmed, thanks for your answer, but what do you mean by “make a software” ?
Thanks
Paul
tarafından
And also, I can't disconnect the battery while the Screen is connected ...
tarafından
Reprogramming the device by a specialist
tarafından
Yorum Ekle
I have the same issue now. Did you find a solution in the end? Would love to know
Puan 0
Yorum Ekle
Yanıtını ekle
Paul Abraham sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 25
Her zaman: 296
