My usb ports are all damaged for my ps3
how can i fix at least one of my usb ports on my ps3 they got bent in the inside
Bu iyi bir soru mu?
İptal Et
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz AtınWhat you need to do is find a donor USB port supplier like a cheap USB hub to do this.
The PS3 uses ports that are not combined ports. Yes, it is possible to replace these. They're only soldered with through hole soldering.
Remove the motherboard from the unit and find the USB ports. From this point get flux and a desoldering braid and remove the USB ports. Replace them all if you have enough. From this point, you need to solder them on being careful not to bridge the solder. If you did this correctly, then your USB ports should be fine and functional.
Son 24 Saat: 2
Son 7 Gün: 16
Son 30 Gün: 71
Her zaman: 6,631
