Hazards and indicators don't work. Combo 1.7 Di
I have changed the relay switch, hazard switch and checked all fuses but still no joy! Just bought the van and need to MOT it. Some fuses / relays were missing but I believe that I have replaced them all.
Bu iyi bir soru mu?
Puan
0
Does the dash show them as working? Check for power to relays. If no power, backtrack until you find power, and whatever it isn't passing through will be the issue. If they have power then check for power at all switches. You're going to have to hunt. Something isn't supplying power when it should. Either it isn't being supplied to the switch, by the switch, to the relay, or by the relay. Also check grounds. If a ground to a relay or lights is bad then it won't work then either.
brandon k tarafından
