Why does my iPod nano lose battery so quick?
I charge my nano until it's fully charged but it runs out of battery about 2 hours later.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
It does sound like your battery is ready to be replaced. Follow this guide to show you how to get to the battery. It is a bit of a PITA due to the size of the Nano. Of course, before you take it apart, you could also give this a try. the battery is available at places like this. I hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
thanks 4 the info but the thing is i just got it about a week ago. Could it b something else?
Not really, you could check on your settings and make sure that your EQ is off etc. You might also try another charger, anything is possible. If you just recently got it, any chance you got some sort of warranty?
thanks sooo much
Maybe Its cause since it is so tiny that the battery should be tiny to so that means a little bit of battery
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 8,157
4 Yorum
My 4 gen ipod mini dies so fast when it's fully charge as I remove of the charger to go low battery what should I do?
nekojenjen1988 tarafından
I got a 6th gen nano and when its fully charged I will unplug it, but it literally dies in 5 seconds.
Alexis tarafından
I have this problem as well ... it's a new Ipod Nano, I charge it fully, I play it, and it dies in less than 2 hours.
antronus10 tarafından
you need to replace your battery. it does require soldering.
Crystal Haugh tarafından
