When I switch it on It's show nothing
When I switch it on It's show nothing but if I use flesh light I see some pictures ..... I did not fix anything
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@mphephu that most likely means your backlight has failed. You can replace it by disassembling your the LCD panel. Be careful with the sheets between the panel and the backlight strips. Make sure that you keep those the same way they are. If you give us the exact model number for your TV we can probably help you further
Bu yanıt yardımcı oldu mu?
Me pasa lo mismo, la enciendo y se ve de forma muy tenue, casi nada, el modelo es SMX40P28NF
@Manuvalde probablemente la misma situación. Las tiras de retroiluminación en mal estado pueden causar eso. Si necesitas ayuda para desmontar el panel, podemos convertir esto en una pregunta propia. A continuación, añadir fotos del interior de su televisor a la pregunta. De esta manera podemos ver lo que usted ve y probablemente le puede ayudar con la sustitución de las tiras de luz de fondo.
she is not taking power
@santoshrai she who? Your TV? Make and model? What is it doing when you turn it on? What exactly happens? Power led lights up?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 197
