Ana içeriğe geç
22 Eylül 2017'de satışa sunuldu. Model A1863, A1905 olarak tanımlanıyor. GSM ya da CDMA olarak 64 ya da 256 GB kapasitelerinde, Altın, Gümüş, ve Uzay Grisi renklerinde satılır.
865 Soru Tümünü görüntüle
People can’t hear me on calls, or FaceTime etc
Hi,
Have got a iPhone 8 , people can’t hear me on any phone calls, FaceTime, etc . Have tried using voice memos to record and doesn’t pick up any sound.
When I record a video with the back main camera it does record sound. And sound plays ok .
Is this a speaker issue? And which one would need changing?
Thanks
Bu iyi bir soru mu?
Puan 1
3 Yorum
Have you tried using the speaker phone mode on calls?
tarafından
Yes still don’t get any joy though.
tarafından
When i call on discord or facetime or instagram my friend cant hear me but i can still hear them. I reset my phone i deleted the apps and downloaded them back and im still having this problem
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
This sounds most likely like a bottom microphone problem. As was already noted, I would try and make certain there’s no debris stuck in the bottom grills. Although it was mentioned to use compressed air, I would recommend using something like Blu tack, or even tape to pull stuff out since that’s generally more effective than trying to blow it inward.
If it looks clear, it may be the microphone itself is not working properly in which case you’d be looking at replacing the lightning dock assembly.
iPhone 8 Lightning Connector Assembly
iPhone 8 Lightning Connector Assembly Görseli
Ürün
$24.99
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Hello,
2 questions:
  • Are you using headphones? And if you are have you tried switching them out?
  • Have you tried blowing out (GENTLY) the speakers with some air?
To remove the dirt in the microphone:
  1. Open some compressed air
  2. Blow it at the grill on the top
  3. Blow into the bottom left microphone
  4. Blow into the mic at back on the right of the camera
  5. Most of the dirt should be gone so people should hear you
Another possibility is in your microphone privacy settings:
  • To turn on your iPhone’s microphone, go to Settings > Privacy > Microphone > make sure the app you’re using for calls if toggled on.
Another possibility (very rarely) is your network settings try this to reset your network settings:
  1. From the home screen, tap Settings
  2. Scroll down to, then tap General
  3. Scroll down to, then tap Reset
  4. Tap Reset Network Settings
  5. Tap Reset Network Settings to confirm
You can also try to force reboot your iPhone and that may help your situation:
Comment forcer le redémarrage de l'iPhone 8
Lastly you may need to replace your speaker if all else fails:
iPhone 8 Troubleshooting
iPhone 8 Earpiece Speaker Replacement
Good luck!
iPhone 8 Görseli
Kılavuz
How to force iPhone 8 to reboot
Zorluk:
Çok kolay
20 seconds
iPhone 8 Earpiece Speaker Görseli
Kılavuz
Zorluk:
Orta
30 minutes - 1 hour
Puan 1
Yorum Ekle
Yanıtını ekle
dan morrill sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 23
Son 7 gün: 129
Son 30 gün: 619
Her zaman: 21,548
