Ana içeriğe geç
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
Update iMac 2008 to El Capitan, tried everything
Good day
I have a 2008 imac 20in with a working El Capitan. Because i was planning to sell it I re installed the OS, but it's giving my the error installer not recognize, damage etc.
I have tried: change date(wifi off) reset the PRAM, removed the battery and still having the error when installing.
The USB I'm using is working, I setup an iMac prior to this unit and I created another USB just to be sure but still having the error.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum
Have you tried using internet recovery?
tarafından
yep, its not working also
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Ah! You’re hitting the expired certificate issue within the installer. Here’s more on this issue: If you've got an old macOS install image, it will probably stop working today
From this mess Apple did update many of the older OS’s. To get a good version download from here How to get old versions of macOS
I recommend setting up a USB thumb drive as an OS installer, First reformat the drive to GUID Journaled using Disk Utility then follow this guide How to make a bootable OS X 10.11 El Capitan installer drive. Then just boot off of the installer to first fully wipe your drive again use Disk Utility wiping it with a pattern so your data is not recoverable. Then use the the OS installer to install a fresh OS.
Bu yanıt yardımcı oldu mu?
Puan 1
6 Yorum:
i have done this already.
On the website, How to get old versions of macOS, the file downloaded is a .dmg file, not an .app file.
tarafından
@jujoe - Double click will unpack it
tarafından
Yup, after opening the .dmg, it will show the .apk file. Then installation doesn't proceed on my MBP 2019, so i can't extract the .app file.
tarafından
@jujoe - Ouch! I guess I'm spoiled, setup my refreshed USB installers from a 2011 iMac. Even still there is a way around the certificate issue using your older installer.
You'll need to alter the Data & Time control panel altering the year back in time and disconnect the time server so your alteration is not reset back to todays year before you've completed the OS setup task. Then use your Mid 2007 iMac to setup the OS installer. So you can then properly wipe your system and install a clean OS.
tarafından
@danj did alter the date and time from 201 to 2016 but still no luck. I used also the release date of El Capitan just to o be sure. Just weird that this is happening now hehe. Thanks mate
tarafından
1 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
jujoe1 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 1,035
