Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
The BlackBerry Pearl 8100 is smartphone developed by RIM.
4 Soru Tümünü görüntüle
Why isn' the trackball working?
trackball works horizontally but not vertically. What's wrong?
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Nintendo Switch Setleri
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Blackberry Pearl 8100 Trackball Replacement this guide should help you to replace the trackball. Of course you could just cleaning any dirt and debris from around it first and see if that fixes it before paying for the part. Google or eBay are your friends for finding the trackball, just make sure you have the right one by checking on the logicboard (under the battery) for the exact model.
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
If you remember "mouses" with track balls on computers that occasionally had to be disassembled to clean not only the ball but the contact points, (usually 4,) then you basically understand the trackball on the Blackberry. I have removed my trackball, cleaned it with denatured alcohol and also used a Q-tip dipped in the same alcohol to clean the contact points. Might not be a permanent fix due to age but it has worked for me before.
Puan 0
Yorum Ekle
Yanıtını ekle
julio wilches sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 853
