Can I replace Lead Acid battery with Li-ION?
Hi guys can you hel me? I need to replaces a battery in a battery powered amplifier (samson xp106) It has a 12v 9ah battery and I´m wondering if I can replace it with a Li-Ion battery. Also if the charging method would be the same.
Thanks in advanced
(also excuseme but my device is not listed in this website)
Bu iyi bir soru mu?
4 Yorum
Can you take a picture of your GEL battery and post it here? Adding images to an existing question
Andrew S tarafından
I just add a pic
AriCohelo tarafından
@aricohelo How does the battery charge currently? Why do you want to replace the current battery with a Li-ion?
Andrew S tarafından
The reason is the weight.
It has a charger 18v 1,5ah, it came with the amplifier. But I can buy another kind of charger and use it outside the amp I guess
