Ana içeriğe geç
21 Eylül 2018'de piyasaya sürüldü. A1921, A2101, A2102, A2104 Modelleri vardır. GSM veya CDMA / eSIM veya nano-SIM / 64, 256, veya 512 GB / Gümüş, Altın, ve Uzay Grisi seçenekleri mevcuttur. ("iPhone 10 S Max." olarak telaffuz edilir)
269 Soru Tümünü görüntüle
iPhone XS Max Motherboard starting to smoke?
I bought this previously water damaged phone Online. I went through all the pieces to clean off the Corrosion the previous owner had caused with his little water accident. Today i put everything back together and as soon as i lastly connected the battery, the Motherboard of the iPhone XS Max started to smoke. I quickly disconnected the battery. What could be the cause?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You have a short circuit on the logic board. This is a common problem, but it doesn’t have an easy solution. There are tons of videos on my YouTube channel (iPad Rehab Microsoldering) showing identifying and solving short circuits. On a Xsmax there’s no “common spot” and it could be between the double stacked layers of the logic board. This is every microsolderers favorite problem to solve—once you identify the cause of the short that is usually the only thing wrong. I’d find a local microsolder who has a microscope and thermal camera to help you find your short.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorumlar:
Thank you very much for this response. I really appreciate it!
tarafından
Yorum Ekle
Yanıtını ekle
Agan Shyqeriu sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 48
