The printer doesn't print on the paper.
My Brother MFC-J4510DW pulls paper in, makes noises like it is printing, spits the paper out and it is blank. The ink is good.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Try pressing the ok button three times.
Try and print.
If no joy check the toner density setting,
Still no joy, clean the drum (different then the toner cartridge.) If cleaning it does not help the drum may need to be replaced.
Sad to say but on a recent printer issue it cost less to replace the printer with a similar, but newer printer, then buying the drum.
Good luck.
Bu yanıt yardımcı oldu mu?
Thank you, mark ray! My grandson finally was able to come over and he was able to get it working, thank to your help! I really appreciate your taking the time to send the help.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 32
