Green light, Fan spin BUT NO DISPLAY -820 000165
I have a MacBook air a1466 (820 000165), after replacing the bios chip, I have green then orange light and, fan spin for a long time but no image, I tried with a flashlight to see if it is a backlight issue.
PPbus_g3h, pp3v42, and pp5v_s4l are present, also r6115 and r 6130 have been replaced after missing them because of the hot air.
since I already know that the MacBook was working fine before u6100 was replaced, can you help me identify the issue? what are the value that I should read on u6100 to see if it is properly soldered?
thanx for your help :)
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
5 Comments:
3.3V on pin 8 which powers the chip.
tarafından
Why did you replace the EFI chip?
Are you sure you got the correctly programed chip?
tarafından
@honakrisi i Mesure 3.32V on pin 8
tarafından
@danj replaced the chip for a password issue, i do not have a chip programmer to check it, buy it from ebay.
tarafından
@nacimux - I would get another and you might want to put the original one back on.
tarafından
Yorum Ekle
