Ana içeriğe geç
The PlayStation 3 Slim is the second version of the PS3 video game console produced by Sony Computer Entertainment. It was released September 1, 2009.
386 Soru Tümünü görüntüle
Stays powered on as long as I press down on the disk drive
I have a PS3 slim. Model chech-3001a. Plug it in and the red light comes on. Press power button and the green light and fan come on for a few seconds then shuts down with no lights. If before I press power button I push down hard on left side of disk drive and hit the power button it will run and stay on. If I let off a little pressure it will shut off again. I took it apart down to the motherboard and looked over with a magnifying glass. Checked for solder connections and for damage. Did not see anything wrong. Anyone have any idea? Thanks
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Have you checked that the controller board for the disc drive is connected properly?
From what i understand, most hardware in the slim is held thru tension from the case screws, kinda sandwiching all the components, if that connector is the culprit and you only need a bit of force on it, you could try to put a soft piece of foam between the drive and the upper case to add that little extra tension you need, but first check that it's seated properly.
There is a teardown on this page for this device, on step 19 third picture you'll see the connector
Bu yanıt yardımcı oldu mu?
Puan 2
Yorumlar:
Hi David. Thank you for your answer. I checked the connector and the drive is seated in all the way. Tried the foam, built it up to get down pressure and still did not work unless i press down hard on the left side of the disk drive.
tarafından
On the side you need to push on you need to put foam there as well
tarafından
Yorum Ekle
The HDD wire is probably dirty or broke?
Puan 0
Yorumlar:
I changed the hdd and disk drive and added foam for pressure. Still same problem.
tarafından
Yorum Ekle
Yanıtını ekle
Tom Casper sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 28
