Ana içeriğe geç
Mart 2016'da Samsung tarafından yayımlanmıştır. Model SM-G930V.
cant remove back plate
HI, I have followed the steps on the replace back plate instruction and for the life of me no matter how much I heat the phone I can not get the back to lift at all not even slightly i have tried heating to the point i need to hold the phone with a towel and tried to lift with suction cup but still nothing any help?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Have you tried to use a spudger and/ore opening picks to separate the glass?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi There,
With the back glass on this device, you need to use a lot of heat. I see in your post you tried this. We use around 60-80 degrees C on our heat pad then use thin metal cards to get under the glass. Once we have that in we switch to plastic cards and run them around the edge. The phone needs to be basically so hot you cant hold it.
Hope this helps.
Eric
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
if you struggle to cut the glue at the plastic card stage you can apply some isopropyl alcohol to the card. Only a small amount though. you don't want it dripping into the screen.
tarafından
Yorum Ekle
Yanıtını ekle
Carla James sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 364
