Ana içeriğe geç
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
151 Soru Tümünü görüntüle
After replacing screen iPad 2 3G reboots when you move it
Hi,
I have repaired like 5 or 6 broken glasses of iPad 2 WiFi before this iPad 2 3G (GSM). I never had a problem before it.
Everything went fine until I was preparing to reassembly the device. I turn it on before fixing the new glass to the frame and I realized that it turns off every time I make a small move in the device.
So now it is completely useless because you cant hold it without get another reboot.
I have tried switching the logic board. I put in this iPad 2 3G the logic board of an iPad 2 WiFi and the worked fine. But then when I put back the gsm logic board the same problem shown again.
Anyone have any experience with this kind of problem?
I am going to make more test, but I think it would be great if we share more info about iPad 2 troubles.
Thanks and keep repairing!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
i had the same problem, the slighted touch anywhere on the ipad made it turn off! after some searching i found what was causing this. apparently the motherboard screws had to be tightened.
as soon as i pressed down on the board it turned off.
took it back out, refitted and tighter the screws, voila!
works like a charm
hope this helps
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
UPDATE:
I have found that the problem is because of the antennas located on both sides of the facetime camera. When you press them the iPad just turn off!
Puan 0
1 Yorum:
So what did you do to fix the antenna problem?
tarafından
Yorum Ekle
well i need help with my screen im trying to find the cheapest place to get a new ipad screen but i dont know where i can get a cheap one from because everywhere i go it cost like £75 or £90 so i dont know what to do with it because everytime i go on it i tap an app and the app wont come on like the keybord that just useless
Puan 0
2 Yorum:
its useless
for me to go on my ipad when the screen wont work
tarafından
cheaper sometimes to get a new one because it by th time ave finished with it it will be full price anyway
tarafından
Yorum Ekle
I too had the problem of my ipad 2 resetting/rebooting when I moved it. When I pulled the screen again I found that I hadn't fully seated the motherboard screws. Tighten and fixed.
Puan 0
Yorum Ekle
Yanıtını ekle
Zrush1 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 3,138
