Why won't my hp photosmart C4280 printer turn on anymore?
One day I push the power button and nothing happens. Before that, my printer worked great. Now all I get is a quick flash from my LCD screen and then it turns black. Nothing. I have tried changing outlets. Nothing. The first power cord I bought worked for a few days then it stopped working. It did the same thing. It would not turn on, just a flash on the LCD screen and turn off. So I bought another one. Same thing. It flashes and turns off. I’ve taken it apart once and thought maybe I would replace the control panel circuitry where the on/off switch is but the guy on the phone talked me out of it. Partshere.com has a lot of printer parts. Check it out. So I’m going to take it apart one more time and thoroughly check to see if I can find something I missed.
IN the meantime, if anyone has a tip or an answer please respond as soon as you can.
Thank you!
Bu iyi bir soru mu?
Does the printer use an internal or external power supply?
Andrew S tarafından
I'm guessing external. The power cord is two pieces. One cord plugs into the wall with a power supply box and then the shorter cord plugs into that and to the printer.
Diane Livingston tarafından
