I can see the icons, the touch works, the screen is black?
iPod Touch 1st Generation works however the screen is black, i can see the icons and the touch works
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Ron, if the icon etc. are visible, that means your backlight is not functioning. The backlight is part of the LCD, and the backlight circuit is on the logic board. I would go ahead and start with the cheaper of the solution, and that is by replacing the LCD. Of course, make sure that you restored the iPod and have done any of the updates and also reset the settings. From the Home screen->Settings->General->Reset All Settings. If none of that works, you are looking at having to either replace the logic board, or replace the coil on it. The replacement of the coil is very tedious, very small and needs some special skills. Check on here for a picture of the coil.
Hope this helps, good luck
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 427
2 Yorum
Thanks for your help, I’m confident that your answer is the problem.
Thanks Again,
Ron
Ron tarafından
You are welcome and best of luck to you.
oldturkey03 tarafından
