Ana içeriğe geç
Repair and disassembly information for the 2020 refresh of the MacBook Air model A2179 with an Intel processor that was released in March 2020.
74 Soru Tümünü görüntüle
Screen goes blank after a few seconds/minutes
HI,
My son's Macbook Air is having some issues with the display. When he turns it on, the image is showing and he's able to login, but after a few seconds, sometimes minutes, a vertical line appears and the screen goes blank.
If connects to an external display, it works fine and there it doesn't show any vertical line.
I already tried resetting SMC, PRAM and NVRAM but it didn't solve the issue.
Does anyone faced the same or have any idea about what might be causing this issue?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Ouch! You've isolated the issue down to the internal display. You'll likely need to replace the internal display assembly.
Can you give us a bit more on what model as Apple produced two sizes 11" & 13" and they also altered the part a few times we also need the year. To make this easier plug in the systems S/N here EveryMac - Lookup then tell us what you found.
Bu yanıt yardımcı oldu mu?
Puan 0
6 Comments:
It's a Macbook Air A2179 from early 2020.
tarafından
I was doing some tests and if I close, open the lid and then move the mouse, I can briefly see the pointer and then it disappears. Sometimes, the image is shown and then goes blank. Can it be an issue with this part? MacBook Air 13" (Late 2018-Late 2020) Display Cable
tarafından
@pedro_ladeira - Sorry the display cable is not likely your issue. This series has an issue within the displays T-CON unit which is that attached on the bottom of the display and is part of it.
tarafından
Since you are so helpful, Dan, I have one last question: Do you recommend getting a display from ebay, which are a bit cheaper than the one that you have mentioned_
tarafından
1 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Pedro Ladeira sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 43
