Why when calling the iPhone switches off
I have replaced the new screen and now when trying to call iPhone switches off?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Does the phone turn completely of or is the screen completely black?
It could be the proximity sensor being damaged / placed wrong, and the phone thinks it is being lifted to the ear and shutting off the screen. Try disconnecting the Front Camera flex and make a call to see if the result is the same (You wont be able to hear any sound from the earspeaker when this is disconnected)
Bu yanıt yardımcı oldu mu?
After looking at this iPhone behavior that must be related to the battery.While on-call batteries consume so much. First, try to replace the battery.
Considering OP just replaced the screen, it more likely has to do with the screen replacement, if the battery was functioning fine before.
@mshalluf , put back the old screen and check if the iphone works well, if so then you know the fault is in the new screen.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 44
1 Yorum
Is the phone turning off or just the screen that turns black?
CaesiumS tarafından
